Question about PIC 16F877A
Discussion in 'Embedded Systems and Microcontrollers' started by chamara, Oct 24, 2011.
  1. chamara
    Oct 22, 2011
    21
    please help me to answer these question......
    Calculate the conversion time on following occasions
    >if a 4MHZ system clock is used to drive the Micro-controller and Fosc/32 is used to drive the ADC module.
    >if the internal oscillator is used to drive the ADC module
  2. John P
    Oct 14, 2008
    1,636
    225
    Section 11.2
    chamara likes this.
  3. chrisw1990
    Oct 22, 2011
    543
    41
    did you actually read the datasheet like we told you to yesterday?
    i told you to read section 11...
    chamara likes this.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Hi Chamara you can be sure that no in this forum will just do the job for you. At least not without a signed contract first.
    BUT if you show some effort and try to do the calculations by your self. Then show us your attempt step by step. You will most probably find someone that will check your numbers for you.
    Just try it and see for your self.
    chamara likes this.
