Hello!
I have recently been playing around with a LM723 voltage regulator as well as trying to learn how op-amps work. So while reading the LM723 data sheet i noted that the current limit sense pins are the base and emitter of a transistor, which pulls the output transistor low when the voltage across them reaches about 0.65 volts. This voltage would normally be sensed directly across the current limit resistor, which would for instance limit the output current to 650mA when using a 1 ohm sense resistor.
So i got this idea i wanted to try, to measure the voltage drop across a resistor with a differential amplifier and feed the output into the current limit pin of the LM723. I taught if this would work, i could vary the gain of the amplifier (or some configuration of the amplifier) and by doing so adjust the output current. For instance with a gain of 10, the current limit would kick in at 65mA instead of 650mA.
I have played around with this on the breadboard and it sort of works (currently only using a gain of 1), the output of the op-amp corresponds with the voltage drop across the 1 ohm resistor and the current limit kicks in, but the output oscillates like crazy.
Attached is the schematic of my experiment and a screen capture from the scope. The blue trace is the output of the op-amp, and the yellow trace is the output of the LM723 regulator.
My question is, what (if anything) could be done to improve this circuit and smooth out the output voltage? Better op-amp, filtering of some sort? I can't quite get my head around why this circuit behaves this way so any input would be appreciated.
best regards
MaggoT
best regards
MaggoT
