Question about one CE replacing - computer mb
Discussion in 'Computing and Networks' started by UnnamedUser159, May 5, 2016.
  1. UnnamedUser159
    May 3, 2016
    137
    Hi there.
    It`s me again.
    Have here one 775 motherboard and have changed some electrolytic capacitors, but for one i didn`t have the same and put higher voltage. Now it`s higher and cooling cannot be installed.
    Of course i attach photos. How to proceed? Do you think i will be able to find 680uf 4v in this size in my country`s(eastern europe) local stores or the value is very untypical? Maybe the biggest store here has only 16,25 and 35V(fujicon) variant and i think they also will be very higher.
    Thanks in advance
  2. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Can't say, as we don't know which country you're in and you haven't told us the size :rolleyes:.
    Can you get the correct cap by mail order?
  3. shteii01
    Feb 19, 2010
    3,504
    512
    When I was looking for replacement caps, I found this advice:
    "For replacements:
    - ESR should be the same or lower.
    - Ripple should be the same or higher.
    - Voltage should be the same or higher. [Without getting ridiculous.]
    - Don't wanna change uF unless you have to.
    - Also make sure it will physically fit both diameter and height."
    wayneh likes this.
  4. BR-549
    Sep 22, 2013
    2,181
    419
    I once had a motherboard that was out of warranty due to age. I called the manufacturer for some parts.
    The manufacturer preferred that they did the repair. They offered to repair the board and ship it to me free, if I would ship it to them.
    Always check with the manufacturer.
    I have received many free parts.
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    capacitors do work installed sideways (bent over to allow for the heatsink)
  6. UnnamedUser159
    May 3, 2016
    137
    One more question :)
    CE 0.47uf 50v replacing on monitor power board.
    I see no such capacitor in main electronic components store - search 0,47 and 470nf;
    What can i replace with ?
  7. shteii01
    Feb 19, 2010
    3,504
    512
  8. UnnamedUser159
    May 3, 2016
    137
    I need to replace it now.
    I know i can replace with bigger value with same voltage, but ask if this can be done in this case.
    I ve heard that not every ce can be replaced with bigger value, same voltage. If i remember correct if the capacitors is used for some kind of protection.
