question about npn clipping from art of electronics book
Discussion in 'General Electronics Chat' started by tpny, Oct 17, 2016.
  1. tpny
    May 6, 2012
    216
    Hi please see pic of page 67 enclosed, I don't understand why the npn clips when input voltage is less than -5v. Please illuminate, thank you!
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
    In order for the output voltage to go lower and lower, the transistor has to conduct less and less. It is the emitter resistor that "pulls" the output down to -10 V. However, the load is another 1 K resistor to ground. When the transistor is completely turned off, the two resistors form a simple voltage divider between GND and -10 V. If the two resistors are of equal value, the middle node is half the total voltage, -5 V. If the load were 111 ohms, the clipping level would be -1 V (-0.999 V).
    ak
    tpny, Sinus23 and wayneh like this.
  3. wayneh
    Sep 9, 2010
    12,389
    3,245
    The text says it clips at an output voltage of -5V, not input. But neither makes sense to me.
    Gaaa, AK beat me to it and even got it right. I had missed he ground symbol which is not the same as -10V. I wish they'd use 0V instead.
    tpny likes this.
  4. tpny
    May 6, 2012
    216
    I also didn't see the ground symbol. second you on using 0v insteadl
    Hi ak, thanks for illuminating duly. But you said if load were 111 ohms, the clipping would be 1v, did you mean -1v? thank you!!
  5. AnalogKid
    Aug 1, 2013
    4,699
    1,298
    Either that was a test and you passed, or my beloved, clicky Focus keyboard is failing.
    ak
  6. AnalogKid
    Aug 1, 2013
    4,699
    1,298
    **even**?
    And, in this unschooled, wild west internet age, they *even* got the ground symbol pointing in the correct direction. even.
    ak
  7. AnalogKid
    Aug 1, 2013
    4,699
    1,298
    I don't. 0 V and GND are not interchangeable symbols or concepts.
    ak
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
  9. wayneh
    Sep 9, 2010
    12,389
    3,245
    You're right, but I think in the example the important thing we both missed was that the point marked with the ground symbol was at 0V. That's our bad, but explicit labelling of that point as 0V might have prevented the miscommunication.
  10. wayneh
    Sep 9, 2010
    12,389
    3,245
    All I meant by that is that you were both faster and correct, not just one or the other. I could have used "also".
