Question about low signal relays
Joined Dec 26, 2008
199
I'm only used to automotive relays.. anyways long story short I'm trying to figure out how to connect looking at the datasheets the layout is different then what I'm used to
I'm looking at a SPDT relay
most show where the coil is but what are the other points? I'm used to markings like 87, 30 and so on
Joined Dec 26, 2008
199
Here is the datasheet
http://www.components.omron.com/components/web/pdflib.nsf/0/EB5C8B538D0F639485257201007DD57D/$file/G5V_1_0911.pdf
and picture
it's a SPDT so I don't know why it shows more then 5 pins
praondevou
Joined Jul 9, 2011
2,942
and picture
5 and 6 are Common (that's like one pin only)
1 is NC
10 is NO
2 and 9 is the Coil
BillB3857
Joined Feb 28, 2009
2,570
Looks like you decoded it right! The relay in your first post is a SPDT (single pole double throw) and the one in Post # 5 is a DPDT. You can put the contacts in parallel for a higher current rating, if needed, or use it to control two isolated circuit loads.
Joined Dec 26, 2008
199
So that's how I can get the full 2 A rating? it's only going to be used on something that going to draw only about 700 mA.
