question about logic pulser
Discussion in 'Homework Help' started by mr.harm, May 6, 2009.
  1. mr.harm
    Nov 24, 2008
    29
    I want to ask about the switch on the logic pulser. it is swithcable between 0.5pps and 400pps. What does (pps) stand for?
    While searching on the internet. I found that two falues make the logic pulser suitable to be used with either a logic probe or an oscilliscope. Which value make it suitable with probe and which with oscilliscope?
    I want some hints on how to use the pulser.
    THANKS..
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    PPS = pulses per second. The lower setting is suitable for a logic probe. Use the pulser as an input - do recall that other logic elements may have to be enabled by having their inputs tied high or low.
