i justed wanted to know wether the output voltage of the ic depends on the external load connected to it . That is to say for a particular value of R1 and R2 will the op voltage change with different values of load resistance RL
I tried simulting the circuit and also tried out the hardware on a breadboard . In all cases the op voltage is changing with the load resistance .
Is this normal or the op is specified only under opencircuit condition ?
Regards .
Regards .
