Question about LM311 Comparator
ut1205
Joined Mar 20, 2014
18
I just purchased a few LM311 comparators and they have two pins that I don't know what they are used for. Google search hasn't helped much.
The pins are labeled "Balance" and "Bal/Strb. Do they do anything that the average hobbyist might find useful?
Bernard
Joined Aug 7, 2008
5,784
T I sais connect bal & bal-strobe together if not using the functions. for open collector operation, ground emitter out, pin 1. Use a pullup resistor, pin7, output, to + Vcc.
ronv
Joined Nov 12, 2008
3,770
The TI data sheet has the most information.
Balance is used to adjust the offset between the 2 inputs to zero as they can be off by about 10 mv. Normally 5 or 10 mv doesn't bother much, but it could. The strobe basically turns the comparator off. So no matter what the inputs are doing the output is floating so other circuits on the output line have control.
