Linearization has many applications.. A lot of times, a system is made linear through a transform, so that it can be controlled whereas a non-linear system is very difficult to control from a stability perspective.
Another use is to make a non-linear response from a sensor, a linear response. A thermister typically has a non-linear response. One would find the function that governs the response, then transform it to a linear one, so that you may gather meaningful data.
The techniques used are:
curve fitting (interpolation), many types, polynomial, etc. least-squares, vandermonde, etc.
regression
lookup tables
thanks both of you folks for providing the information.
Steve, about the lookup tables - what is the general concept of developing such a table. For example a Linearization table having Voltage vs Temperature. How does this table related each voltage value to a corresponding temperature reading, I guess I am interested to know the high level concept of the algorithm that goes into developing such a table.
The advantages of using lookup tables are when the function requires a high degree polynomial to interpolate, and the many multiplications and summations would take too much time and memory, and be subject to rounding errors, etc. Also, lookup tables are the fastest way to get your result.
There are at least three distinct uses of the word.
Firstly if a transfer curve (output v input) is not a straight line (non linear) linearisation involves substituting a linear function (straight line) for a small section of the transfer curve, to make calculations/ formulae easier.
For exmple the transfer curve for a FET is parabolic or worse, but can be approximated by a straight line in it's 'linear' region of operation.
This is not quite the same as 'correction tables' that used to be common on the back of meters and such to acount for the fact that they were non ideal, not exactly 'linear'.
Secondly 'linearisation' occurs when feedback is applied to an amplifier. This refers to the control of gain v frequency one obtains by the use of feedback.
Thirdly, Linearisation is used in many fields of numerical maths to indicate the substitution of a linear function for a more complicated function. This is often done in Finite Element analysis where repeated applications of a simple function will converge to the solution with any required degree of accuracy.
Steve, you are correct, I didn't read the bit about the sensor properly.
The simplest way to linearize a sensor is to limit the range of operation so that the output of the sensor approximates to a linear function over the small range.
