Hi everybody,
I was able to salvage a power transformer from a APC 1000 watt UPS unit and being trying to find more info on this baby but nothing on Internet.
I have included a picture so you can get a better feel for it.
Right now i am using the primary White and Black wire and i guess i can make a linear 13.8Vdc 20~40Amp power supply with it.
Its a 430-1217A Rev.3
LEI-4 E154515.
This thing weight is 16 pound 5 ounce. It would make an anchor for sure.
The primary consist of 4 wires, White-Black-Yellow-Blue (12 Gauge) in that order.
The secondary are Black-White (10 Gauge).
Here are some value i have taken between the following wires on the primary.
White-Black..= .29 Ohm with a 15.75 Vac on secondary.
White-Yellow.= .30 Ohm with a 13.75 Vac on secondary.
White-Blue....= .34 Ohm with a 12.10 Vac on secondary.
The following combination will pop a circuit breaker for sure.
Black-Yellow = .087 Ohm
Black-Blue = .13 Ohm
Yellow-Blue = .08 Ohm
Pappy
LEI-4 E154515.
Pappy
