Hi guys, new guy here so I ask for your patience as I learn the site. My question is about isolation transformers for lightning protection. I repair Auto Transfer Switches 200 - 1000 amp. They are installed on farms and see a lot of lightning in some areas. The Electronic Controllers (PCB) receive lightning damage many times in some areas. They cost 1000 to 3000 dollars. Would an isolation transformer help prevent this at all? Another concern is...the controller monitors the voltage level and sends an engine start signal if the voltage drops or rises above the parameters set. Is there any or much difference in the primary and secondary voltages. Thanks in advance.
