QED uses virtual particles (actually photons) to mediate the repelling force between like charges. Emitting a virtual particle causes a reaction, and capturing the particle causes another.You refer to virtual particles. What the heck are you talking about? What particles?
It would appear a wrong interpretation of my previous post was made. I was asking in a rhetorical way, why the generator behaved in those ways. I did intend for a reader who held these assumptions to question them and, if not do the experiment himself(rarely happens anymore), to go to the web and search for information on why/how magnetic fields could remain stationary while a magnet rotated.Kermit2 appears to feel they are somehow 'fixed' to the source, so that if you rotate the source, the lines, and hence the field will rotate.
I asked you first. You state there is a particle, then name it. A permanent magnetic field (according to latest theory as I understand it) is caused by the spin of an electron. If enough electrons are oriented the same way the field becomes noticeable. If not they they all cancel. An electromagnet does it differently, but it still depends on electrons, the circular winding of a coil concentrates the field which is always present in a wire conducting electricity.actually it does have to do with magnetic fields and induction, well from what I know. The Virtual photon in QED is the Force carrier for not only the Electric charges but also the Magnetic field. If I am wrong, then please tell me and why and what is really the force carrier for the Magnetic field.
For induction the reason it is important is because in say a conductor, there are electrons and these electron inherently have a their own magnetic field due to their spin, and orbit or movement. As the you apply a voltage, these electrons move around the conductor setting up the magnetic field around it. When you try to shut off the Conductor, the initial field starts to collapse, if the field is made of energy and the virtual photons are the force carrier, then I would assume the field and the virtual photons are in someway intertwined. As the field collapses, the field will start to cause a force (Virtual Photons) on the electrons, causing them to want to keep moving in there original direction, if you just cut the circuit, this will cause a huge increase in voltage because of the charge buildup at one end due to the field acting on the electrons (virtual photons). Even though there is no connection at this point, the collapsing field still causes a force on the electron's and this force is caused according to QED from the virtual photons.
So that is why according to what I know, the virtual photons have a lot to do with Magnetic fields and induction, I just haven't found out why a steady state field doesn't induce and a changing does?
It is comments like this which formulated my interpretation. Let me ask, what makes you ponder this? Give me a guess as to why you think a magnectic field would roatate with its source?why/how magnetic fields could remain stationary while a magnet rotated.
Not as far as I'm concerned. It's your post though, so you can do this if you wish.Should I edit my previous response? I looked at it again, and I don't interpret the way you did, but I wrote it, and I'm not you, so.....
I'm typing, but your eyes are deaf or something.It is comments like this which formulated my interpretation. Let me ask, what makes you ponder this? Give me a guess as to why you think a magnectic field would roatate with its source?
There is an experiment that appears to shed some light on this. I have a couple of magnets stuck to my drill press to hold pilot drills and some common sizes in easy reach. The drills are themselves magnetized, making classic bar magnets.Kermit2 appears to feel they are somehow 'fixed' to the source, so that if you rotate the source, the lines, and hence the field will rotate
I started to write some rebuttal to correct your mis-interpretation of my beliefs and why you don't need to 'teach' me anything, but YOU are waste of my time at this point.
Good day. And I hope you get the 'interpretation' of this post right where I aimed it.
My guess is that the field produced by the tool is hardly uniform.Is this showing a fixed field rotating with its source, or does some other explanation apply?
by Robert Keim
by Jeff Child
by Jake Hertz
by Aaron Carman
