Can you explain me why this is the correct equation? I understand the steps, but I thought that the correct equation was (Vd-Vb)*(C5*s)+(Vd-Ve)/R6=0, i.e. the sum of the currents is just 0. That makes Vd positive in my equation and Vb and Ve negative.It's a simple algebra error. Let's look at it step by step. Start with this equation:
Vd * (1/C5+1/R6) = Vb * 1/C5 - Ve * 1/R6
Ok, I understand this is the standard. It's just that I learned to write them with Z's (e.g. Vx*(1/Z1+1/Z2) - Vy*(1/Z2) = 0), and (wrongly) assumed that R and C were just conventions to make it easier to relate the symbols to the actual components. I believe I have formatted them properly this time:I have to say that this is a really bad practice. It's what WBahn is on about because it makes someone who doesn't know that you're going to make this "transformation" think you have a problem with units. You shouldn't use the symbol C5 to mean one thing at one moment, and then something else later.
Rich (BB code):
0. Vd - Vc = 0
1. Vout - Vf = 0
2. Va * (R4+R2+s*R2*C2*R4) / (R2*R4) - Vin / R2 - Vb / R4 = 0
3. Vb * (R5+R4+s*R4*C5*R5) / (R4*R5) - Va / R4 - Vd * (s*C5) - Vc / R5 = 0
4. Vc * (1+s*R5*C4) - Vb = 0
5. Vd * (1+s*C5*R6) / R6 - Vb * (s*C5) - Ve / R6 = 0
6. Ve * (R7+R6+s*R6*C7*R7) / (R6*R7) - Vd / R6 - Vout * (s*C7) - Vf / R7 = 0
7. Vf * (1+s*R7*C6) - Ve = 0
By the way, do I see this correctly: if the overall transfer function is a multiplication of the transfer functions of the two separate filters, then Vd is like a source for the second stage?
