Question about frequency response of a transfer function
Discussion in 'Math' started by hunterage2000, Jun 26, 2013.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    Can someone please tell me the equation or the reason how the transfer function
    G(s) = 1/(s+2) is converted to
    G(jω) = 2 - jω / ω^2 + 4
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    How us the function:
    f(x) = 3 + 9x
    converted to
    f(2y) = 3 + 18y
    Having said that, what you have written is wrong.
    G(jω) = 2 - (jω / (ω^2)) + 4
    Don't forget good ole order of operations!
  3. hunterage2000
    May 2, 2010
    402
    This is what the book says. It somehow goes from G(S) = 1/S+2
    to G(jω) = 2 - jω / ω^2 + 4. I have attached what it says.
  4. LvW
    Jun 13, 2013
    674
    100
    It is correct - from a formal mathematical point of view.
    Multiply numerator as well as denominator by (s-2) and replace s=jw.
    Then you arrive at the final expression.
    As far as the transfer function (and its interpretation) is concerned you now have pole-zero pair that cancels out.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    I would think the correct form is
    G(j\omega)=\frac{(2-j\omega)}{(\omega^2+4)}
    What pole-zero cancellation? Isn't this simply a case of rationalization of the denominator?
  6. LvW
    Jun 13, 2013
    674
    100
    Yes - in post#1 the brackets are suppressed.
    The original expression has no zero at all.
    However, the final expression has one zero at s=2 and a pole at s=2.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    G(j\omega)=1s^{-1}\frac{(2s^{-1}-j\omega)}{(\omega^2+4s^{-2})}=1s^{-1}\frac{(2s^{-1}-j\omega)}{(2s^{-1}+j\omega)(2s^{-1}-j\omega)}
    Here, s is 'seconds', which is why I think it was a stupid convention to adopt s as the variable for the Laplace transform. The 1s^-1 out front is to remove time from the transfer function as a whole, which is important. Other than that, I have to assume that the transfer function is a straight gain and not a transgain. Let the mathematicians do what they want, the EE community should have adopted something else, just like they adopted 'j' instead of 'i'. But, they didn't ask me, so....
    A cleaner way to express this is to define
    \omega_0=2\frac{r}{s}
    resulting in
    G(j\omega)=0.5\omega_0\frac{(\omega_0-j\omega)}{(\omega^2+\omega_0^2)}=0.5\omega_0\frac{(\omega_0-j\omega)}{(\omega_0+j\omega)(\omega_0-j\omega)}
    or even better
    G(j\omega)=0.5\frac{(1-j\frac{\omega}{\omega_0})}{(1+\left( {\frac{\omega}{\omega_0}} \right) ^2)}=0.5\frac{(1-j\frac{\omega}{\omega_0})}{(1+j\frac{\omega}{\omega_0})(1-j\frac{\omega}{\omega_0})}=0.5\frac{1}{(1+j \frac{ \omega }{ \omega_0 } )}
    The first form makes it appear that there is only a zero at 2r/s, though if you notice the ω^2 in the denominator then you have a big hint that something else is going on. But by expressing things in pole-zero form, it becomes clear that this is a system with a DC gain of 0.5 and a first-order low-pass characteristic with a cutoff frequency of 2r/s.
  8. LvW
    Jun 13, 2013
    674
    100
    Yes - sometimes it is confusing.
    By the way - that is the reason I prefer to write
    w=2 rad/sec instead of w=2r/s.
    (The fact that the circuit is a first order lowpass can be derived, of course, also from the first form of the transfer function in the s-domain).
  9. t_n_k
    Mar 6, 2009
    5,448
    783
    Yes I see your point. I guess one could then arbitrarily state that any transfer function can be regarded as an irreducible function multiplied by an infinite array of unique matched pole-zero pairs.
    I tend to reserve the idea of pole-zero cancellation as a design "tool" for making improvements in system stability.
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    The final expression is not a function of s, but of jω. It has a zero at jw=2r/s and two poles at jw=±2r/s. If left as a function of s, it would still have two poles, one at +2r/s and one at -2r/s.
  11. LvW
    Jun 13, 2013
    674
    100
    OK - from the mathematical point of view this is correct.
    However, does this makes sense? What means jw=2rad/sec ?
    (left side imaginary, right side real).
    Can we measure - after setting s=jw - that the transfer function has a zero or a pole, respectively, at w=2rad/sec? No - we cannot.
    Thus, determination of poles and zeros for a transfer function makes sense only in the s-domain (complex s-plane).
    Present example:
    * Original function: Real pole at sp=-2rad/sec
    * After manipulation:
    Real zero at sz=+2rad/sec and two real poles at sp1,2=(+-)2rad/sec
    To t_n_k:
    I strongly do NOT recommend this method. Neither does this "design tool" improve stability nor has it any other advantages. You never can match both frequencies and a mismatched pole-zero pair has severe disadvantages in the time domain. Sometimes a pole or a zero cannot be avoided - and in this case one can try to make a compensation. However, that`s another situation.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    No argument on that score - someone should tell the professors skilled in the art to desist from discussing the concept with their students.
