question about flyback
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Aug 14, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    diode in primary side of transformer which help dissipate energy from leakage inducatance of the primary should be fast reverse recovery my question is what if slow what will happen
    and second question what is the different between force revese recovery and reverse recovery in FET OR IGBT
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The diode will act like a short circuit, as "standard" diodes turn on fast enough, but are very slow to turn off. This leads to high power dissipation, and diodes popping like popcorn.
    TAKYMOUNIR likes this.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Where is the diode in a standard flyback converter on the primary side of the transformer, if not as part of a RCD snubber as I posted in your other thread?
