question about flyback diodes - AC/DC
Discussion in 'General Electronics Chat' started by dayman, Oct 29, 2015.
  1. dayman
    Jul 29, 2013
    21
    Im working at a plastics molding site and im working on creating as built drawings for some of their older machines
    Im seeing that the PLC output is controlling the 120V contactors
    24VDC and im seeing that theyre tied to a large diode
    the projects engineer said that it's a surge protector, I believe its working in the same way that a flyback diode does
    Im just curious as to why it would be used on 24 volts and not on 120 VAC coil, Ive seen a few contactors using AC but none of them used anything like this
    also the way its wired as ive drawn, should this be tied back to N, instead of just looping around just the coil?
  2. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    That looks more like an R/C snubber to me, usually associated with AC coils, if DC coils they should be a rectifier, 1n4007 etc.
    They appear to be Telemecanique contactors, they actually have suppresors that fit directly across the coil, no wire leads.
    Max.
    Johann likes this.
  3. dayman
    Jul 29, 2013
    21
    yes they operate with 120 V coils
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    Only relay coils driven by DC will have a diode. AC relay coils will never have a diode by itself.
    If there is something across an AC coil, it is likely a low-value resistor in-series with a capacitor (shows open with an Ohmmeter), or a MOV.
  5. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    You haven't confirmed the coil type, AC? DC?
    Your sketch shows DC but the component you point to is a RC snubber.
    Max.
