Question about first order highpass filter
Discussion in 'General Electronics Chat' started by Kneus, Nov 21, 2013.
  1. Kneus
    Nov 21, 2013
    Hi Guys,
    I wanna know how to implement the first order high pass filter with 3dB cut-off frequency at 0.05Hz.
    For example if I have a 230V AC as input I want to know how to calculate the ouput...
    I have tried some methods, but I want to know how you guys would do it because I dont know if my answer is correct.
    All help is welcome
    THANK YOU!!
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    What is it loaded with? (Load Impedance, Load current requirement)?
  3. Veracohr
    Jan 3, 2011
    559
    77
    The output frequency response? Or the output at a particular frequency? Is it a LC or RC filter?
    Kneus likes this.
  4. #12
    Nov 30, 2010
    16,657
    7,302
    It always takes at least 2 parts to make a filter, even if one of them is the impedance of the load. You have given us little to work with.
    Kneus likes this.
  5. WBahn
    Mar 31, 2012
    18,079
    4,917
    How can we tell you if your answer is correct when you haven't given us a clue as to what your answer is?
    You haven't even told us what frequency your 230V AC signal is at? 50Hz? 60Hz? 400Hz? What?
    If it's at 50Hz, then your signal is two decades higher than your cutoff frequency of 0.05Hz, meaning that you will be down 40dB. Each 20dB is a drop in voltage of a factor of 10, to the output voltage will nominally be 1% of the input voltage, or 2.3V AC.
    Kneus likes this.
  6. LvW
    Jun 13, 2013
    674
    100
    Kneus, have you already a rough estimate om the parts VALUES you need?
    Kneus likes this.
  7. Kneus
    Nov 21, 2013
    Sorry guys for taking so long to reply...But i will answer your questions with yet another question so you could understand the background of what i am dealing with...
    So I have a measurment on a one phase line 50 Hz 230V(RMS)...The measurements are done with a frequency of 200Khz so the values are instantanious values (thats how its called)
    Now i have to calculate the Flicker level of line on the measured line according to the data (measured) I have. The data consists of voltage and current values. But to calculate the Flicker we only need the voltage values.
    According to IEC 61000-3-11 standard this is done by the following please read this pdf file page 25 to page 30 (chapter 2.4)
    http://alexandria.tue.nl/extra2/200911297.pdf
    Here they state that in order to calculate the Flicker you have to put the instantanious Voltage values in 5 different blocks.
    Block 1 ...constists of calculating the Voltage RMS value over a periode of time measured this is in my case 233V
    Block 2 is the quadrent of the ouput of block 1 so 233^2= 54289 V
    In Block 3 you need to use high pass filter and low pass filter with all the values needed provided
    NOW this where i am stuck i have no idea how to do this ...So i hope you understand now and can help me with this..
    THANKS ALOT FOR THE REPLIES AND THIS TIME I WILL BE ON THIS SITE 24/7 :D
  8. crutschow
    Mar 14, 2008
    13,469
    3,356
    Please don't double post about the same problem.
    Kneus likes this.
