Question about diode logic gate
Discussion in 'General Electronics Chat' started by The King of Electronics, May 12, 2013.
  1. The King of Electronics
    May 12, 2013
    Hi everyone,
    why we use resister when we design AND/OR-logic gate ?
  2. MrChips
    Oct 2, 2009
    12,646
    3,458
    The resistor R presents a load.
    Without R (R = 0) you would destroyed the diodes whenever A or B is connected to GND.
  3. The King of Electronics
    May 12, 2013
    This happen when we replace R with short circuit, what about replace R with open circuit ?:confused:
  4. kubeek
    Sep 20, 2005
    4,691
    806
    The diodes would be off and you would have undefined output voltage.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    If you were to draw a truth table of the gate you show, and use Vcc to represent a logic 1 and zero volts to represent logic 0, it will become clear. Now, take the two diodes and turn them around and instead of having the other end of the resistor tied to Vcc, tie it to ground. What do you wind up with in that configuration?
  6. MrChips
    Oct 2, 2009
    12,646
    3,458
    Then the circuit will not work on its own but will rely on the load that it is connected to.
    (gees, I hate dangling prepositions.)
