Question about Data Saving,
Discussion in 'Embedded Systems and Microcontrollers' started by Boshehab, Nov 26, 2008.
  1. Boshehab
    Nov 26, 2008
    Is there any way to use store data from a temperature sensor into the flash or rom of the atmega microcontrollers?
    Is it possible to interface a memory card (micro SD) with the same microcontrollers in order to data on?
  2. leftyretro
    Nov 25, 2008
    394
    Of course, both are possible. Saving to EEPROM is the simplest but has limited space.
  3. Boshehab
    Nov 26, 2008
    do you know how ?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You need to select a device, get the data sheet for it, and analyze the interface signals to see if they are compatible with your AVR uC. A memory card may work with little problem. It also might be easier to use a serial memory device.
    Much depends on the particular AVR uC you have, what interface protocols it has built in, and how many I/O pins are available for signaling to the memory device.
  5. mindmapper
    Aug 17, 2008
    34
