Question about crystal oscillator
beenthere
Joined Apr 20, 2004
15,819
Crystal oscillators tend to be single frequency devices, although they can be used at harmonic frequencies. Here is the Wikipedia article about them - http://en.wikipedia.org/wiki/Crystal_oscillator.
If you are careful about layout and bypassing, the oscillator would be reasonably stable. But it won't tune to a different frequency, although you can always drop in another crystal.
gaetan8888
Joined Nov 14, 2008
50
Hello
In the web site it say that you can adjust the frequency by changing C1 value, so I would use a triming capacitor and replace it by a fix cap wen I would have the right frequency.
Thank
Bye
Gaetan
SgtWookie
Joined Jul 17, 2007
22,230
Read it again!
Values of capacitor (C1) and xtal (X1) to be varied for required frequency.
The crystal sets the basic frequency.
It's possible with careful tuning to get the circuit to oscillate at various overtones of the crystal's fundamental frequency, but these are basically multiples of the fundimental.
If you want xtal stabilized clocking at various rates, you'll need to start out at a higher frequency and use clock dividers.
gaetan8888
Joined Nov 14, 2008
50
Hello
Here around I can not find a 11.2896 mhz crystal, and order it by mail would cost me quite to much high price for the minimum shipping cost.
I only have a 11.275 mhz crystal and a 11.840 mhz crystal.
So I did think to use an oscillator that I can adjust a bit the frequency.
Thank
Bye
Gaetan
SgtWookie
Joined Jul 17, 2007
22,230
KL7AJ
Joined Nov 4, 2008
2,229
A crystal oscillator can be "pulled" for a maximum of 700 ppm.
See the design notes in the PDF.
Greetings,
Bertus
And you REALLY have to work at it to get that much "rubber". I used to build VXO's, and by the time you got them working right, it was faster to regrind the crystals!
eric
bertus
Joined Apr 5, 2008
22,270
As eric KL7AJ already told you, the old crystals could be grinded.
I used to do it with VIM on a glassplate, to get the frequency higher.
If you wanted a lower frequency you painted the crystal with black lacquer.
Greetings,
Bertus
KL7AJ
Joined Nov 4, 2008
2,229
Greetings,
Bertus
You could also use McClean's toothpaste instead of Vim. It goes without saying that anything that could grind quartz down probably did wonders for your teeth too!
Eric
gaetan8888
Joined Nov 14, 2008
50
Hello
Looking at Crystals Oscillators
There is various types of Crystals Oscillators with different kind of output, which ones, in those output types can drive four 74HCT74 ?
Crystals Oscillators output types; TTL - HCMOS - LVPECL - LVDS - LVDS
Thank
Gaetan
bertus
Joined Apr 5, 2008
22,270
flat5
Joined Nov 13, 2008
403
How far can you bend a ceramic resonator. Is this a useful technique to get more spread that a xtal provides yet still have a good measure of frequency stability?
gaetan8888
Joined Nov 14, 2008
50
Hello
Fox made the FXO-HC52 serie, a very low jitter ceramic resonator crystal oscillator, at very low price and seem quite interesting.
But is it true that the ceramic resonator crystal oscillator have less precise timing and do age more rapidely compared to the quartz crystal oscillator ?
Maby those new models of ceramic resonators crystal oscillator would be much better ?
Thank
Bye
Gaetan
leftyretro
Joined Nov 25, 2008
395
Hello
Thank
Bye
Gaetan
Quartz crystals will always be superior to ceramic resonators as it a material with a much high Q value.
Lefty
