Question about common-collector amplifier page
Discussion in 'General Electronics Chat' started by jut, Mar 12, 2008.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    http://www.allaboutcircuits.com/vol_3/chpt_4/6.html
    "It is called the common-collector configuration because (ignoring the power supply battery) both the signal source and the load share the collector lead as a common connection point:"
    I'm confused, why is this called the common-collector if the collector on the transistor only connects to the positive side of the battery?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    "Common" in this context does not mean "ground." It means "shared" or "mutual."
  3. Shelton
    Member
    Mar 13, 2008
    19
    The input is connected to the Base
    The output is connected to the Emitter
    Whats left over? the Collector - hence its a common collector.
    This works for all three configurations.
    Try it! :)
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    In this case, the collector can be connected to Vcc or to ground. In the case of a NPN transistor, it will be connected to Vcc. In the case of a PNP transistor, it will be connected to ground.
    So, it is better to think that "common" means that it is not connected to the input or the output, although it does not always means that the "common" is connected directly to ground or Vcc.
  5. Colin Mac
    Member
    Mar 11, 2008
    18
    The collector is common to both the input and output.
  6. jut
    Aug 25, 2007
    224
    Well OK. If you imagine the load power supply battery shorted out, then the signal source and the load share the Collector as a common point. I was imaging the power supply battery being open.
    Thanks for the help guys.
