The forward voltage drop of the diodes must match the base-emitter voltage of the outout transistors.
1N4148 little diodes would match 2N3904/2N3906 little transistors but their output power would be very low.
1N400x power diodes would match TIP31/TIP32 medium power transistors.
I have never heard the term "rubber diode" before. We call it a Vbe multiplier transistor.
If it is mounted on the heatsink for the output transistors then it thermally adjusts the current to be constant when temperature changes would make the current much different if it wasn't sensing the temperature.
