A current source like this is an idealisation. For a practical implementation of such a circuit, a negative supply driving something like a transistor current source would be needed.I think you are wrong in this one. What the current source really does is creating a negative voltage in the emmiter VE=-0.3*8=-2.4V which means that even if the source at the base is 0 volts then Vc=5V which is bigger than Vb=0V which is bigger than the Ve=-2.4V so the transistor will conduct all the time because it is in the active region.
In other words, as soon as I have created an emmiter voltage Vbe volts smaller than the lowest possibly base voltage, the transistor conducts.
In addition, the emulator I am using has osciloscope and I have checked the output. It is not a rectifier, it is a full wave amplifier.
But your schematic does not show a negative supply for the current source, it shows only a positive supply.I think you are wrong in this one. What the current source really does is creating a negative voltage in the emmiter ...
The current source is ideal and it is indeed creating a negative voltage in my circuit, and I am quite sure that it is working properly.But your schematic does not show a negative supply for the current source, it shows only a positive supply.
Why make a class-A audio amplifier? It wastes a lot of power making heat even when it is not playing.
by Duane Benson
by Jake Hertz
by Jeff Child
by Jake Hertz
