Question about Circuits (IR)
Discussion in 'General Electronics Chat' started by ssolitare, Dec 13, 2010.
  1. ssolitare
    Nov 29, 2010
    34
    Say in a DVD player, what are the things that need to be ON in order for the DVD to still receive IR signals?
  2. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    There are more powersupplies in a IR controlled device.
    There is the switched main-powersupply and the standby-powersupply.
    The standby-powersupply powers the IR reciever and can switch the main-powersupply on.
    If you want to know more about the IR signals itself, take a look at the links of this page:
    http://www.educypedia.be/electronics/televisionrc5.htm
    Bertus
  3. mtripoli
    Feb 9, 2010
    44
    8
    The POWER switch...?
    :D
    Mike T.
  4. ssolitare
    Nov 29, 2010
    34
    lol mike.
    Speaking of the the standby power supply, functions like the internal clock still remain.
    Like if I wanted to make a DVD player where OFF meant that it still just receives IR signals and then executes from there, but there is no clock or anything else extra functioning prior to that.
  5. ssolitare
    Nov 29, 2010
    34
    I am bumping this. :)
  6. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    You would still need a small standby powersupply for the IR reciever.
    It can be smaller as you do not need to supply the clock too.
    Bertus
  7. ssolitare
    Nov 29, 2010
    34
    Edited this out.
  8. ssolitare
    Nov 29, 2010
    34
    And this too.
  9. ssolitare
    Nov 29, 2010
    34
    So I am coming back to this.
    Little energy is needed for this, so would it just make more sense to power the IR by battery?
    If the power source were from a wall, I am trying to picture how I would only take that very small amount of energy.
    Transformer and diode to prove the stable DC that I need, so then do I just pile on resistors to get the current down? Is there a more efficient way from a wall plug?
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    The circuit will only draw what it needs, a battery would be more wasteful.
    Get a Kill-A-Watt device (some libraries rent them) and plug your DVD player into it. See how little it draws in standby vs when on. Same goes for a TV.
    PS want to save energy? Check how much an old TV draws compared to a modern Energy-Star LCD.
