Question about circuit diagram of trasistorize full-adder
Discussion in 'General Electronics Chat' started by hackerz, Aug 19, 2009.
  1. hackerz
    Aug 5, 2009
    7
    can you give me a diagram and materials of simple transistorize full-adder circuit?tanx
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Much easier to use a logic IC.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    And if you MUST have this (say, for homework) start from chip and reverse engineer using RTL or DTL.
  4. count_volta
    Feb 4, 2009
    435
    24
    This is a full adder schematic.
    This is a CMOS transistors OR gate.
    There is an OR gate in the full adder logic schematic above. If you google them, you can also find cmos AND gates, cmos xor gates.
    And then fill in the blanks, i.e. replace the gates in the full adder schematic above with cmos transistors and you got it. Simple. ;)
    P.S. if you want to do it in real life, yea use a logic chip. But its possible to make it using cmos.
