Question about charge pumps capacitors
Discussion in 'General Electronics Chat' started by yuvi1, Feb 12, 2014.
  1. yuvi1
    Feb 1, 2013
    37
    hi all,
    I know that charge pump is a DC to DC converter that uses capacitors for creating an output voltage that is either higher or lower than the input voltage .
    how does it creates at the output a higher voltage than the input ?
    is it lowers the current at the output in the same ratio ?
    thanks !
  2. Potato Pudding
    Jun 11, 2010
    684
    92
    A charge pump restacks voltages.
    For a voltage increase-
    You charge a capacitor and then raise the negative node to a positive value, then take current off of the positive node.
    With a 5 Volt supply you would likely charge the capacitor to 5 Volts then change the connections so that the capacitors negative node is raised to 5 Volts which would make the positive node 5 Volts, + 5 Volts. Diode drops will reduce that to less than 9 Volts actual output. Repeat continuously and very fast to get a reasonably steady output.
    The load current must be very small or else you will end up with much less than 9 Volts out in this example.
  3. yuvi1
    Feb 1, 2013
    37
    first of all , thanks for your answer
    and regard to your answer:
    how do we change the connections ? with some king of switching ?
    voltage increase (dc to dc) must have some king of switching in order to work ?
  4. crutschow
    Mar 14, 2008
    13,523
    3,392
    Yes, you need switches. Typically MOSFETs are used for that purpose.
