Question about Ce^at
boulwabd
Joined Oct 12, 2016
I am reading my textbook and have been trying to figure this out all night and day, why is a = r +jw0 and what is r? The book described this as "a in rectangular form" but I was under the impression rectangular form specified a real x component and an imaginary y component similar to cartesian fashion. I understand that r is the real part and jw0 is the imaginary part but can't quite grasp why we used the fundamental angular velocity instead of a "y" value or click on the context and how it relates to the periodic complex exponential e^jw0t. Any help is appreciated, I've moved on but would like to fundamentally understand how this is derived.
ci139
Joined Jul 11, 2016
1,898
withveryvaryingfrequency it jω₀t likely won't describe much anything - as well as - Xc XL are statistically derived averages for steady frequency time window being examined
▼. . . the imaginary unit being another statistical variable - that just enables to describe things more comfortably -- considering the θ=(ω₀-jr)t . . . shows i haven't read some 30 chapters of something that points out extremely limited use of such . . .
. . . ? phasors - never heard - i'm the differential cat
http://electronics.stackexchange.co...umbers-to-represent-amplitude-and-phase-of-ac
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/impcom.html
WBahn
Joined Mar 31, 2012
29,979
Just expand out the exponential term:
e^{at} \; = \; e^{\(r \, + \, j \omega_0 \) t} \; = \; e^{rt} e^{j \omega_0 t}
In the first factor, r is almost always negative, so e^(rt) represents a magnitude that is decaying exponentially with time. If r = 0; then the magnitude is a constant. If r is positive, then the magnitude is growing exponentially with time.
The second factor represents a signal that is varying sinusoidally with time at frequency w_0. Depending on how this were set up, the actual signal of interest is usually either just the real part or just the imaginary part. In either case we have a sinusoid.
