Question about cascaded transfer functions
Discussion in 'Homework Help' started by Amanda_Riley, Apr 2, 2011.
  1. Amanda_Riley
    May 12, 2010
    22
    I have two 1st order transfer functions of:
    5/s+5 and 10/s+10
    when they are cascaded you get 50/(s+5)(s+10) if an impulse function of 1 is input.
    How is the output 10e^-5t - 10e^-10t?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    By cascaded you mean connected in series? If yes, then the Transfer Function that occurs is independent of the input of the system.
    I really messed up this one. The correct answer is given by the method explained by the post next to mine.
  3. dewasiuk
    Feb 14, 2011
    24
    If you use partial fraction expansion, you can easily take the inverse laplace transform to transform your terms to the time domain.
    50/(s+5)(s+10) = a/(s+5) + b/(s+5)
    Solve for both a and b, and then you can then easily apply laplace techniques, if you've already learned them.
    My solution: http://img864.imageshack.us/i/laplace.jpg/
    Table of transforms: http://www.intmath.com/Laplace-transformation/Table-laplace-transforms.php
  4. Amanda_Riley
    May 12, 2010
    22
    Thank you for this x
