question about capacitors
Discussion in 'General Electronics Chat' started by kibbles18, Jun 27, 2010.
  1. kibbles18
    Jun 27, 2010
    5
    In my book for beginner electricians, it says that capacitators "can smooth a pulsating current from a power supply into a direct current". I dont know what this means really. What would be an example of a pulsating current? It takes in a pulsating current and outputs a DC current?
    the last question i have is when a capacitator is hooked up to say a 9V and fully charged, does it discharge right when it is charged or when something that needs electricity like a bulb is hooked up to it?
  2. Jaguarjoe
    Apr 7, 2010
    770
    90
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not too long ago I had a circuit that was feed from a 9V battery. The battery was well discharged, and the circuit put a heck of a wave on the power supply rails, around 4VP-P or so. A capacitor across the power supply rails will minimize this, the more capacitance, the better it works.
    In some ways capacitors resemble batteries. They take and hold a charge. A battery tries to keep a constant voltage for the most part (this is not a hard rule), whereas a capacitor doesn't even come close (constant voltage that is).
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A capacitor blocks DC, and passes the effects of AC.
  5. kibbles18
    Jun 27, 2010
    5
  6. Norfindel
    Mar 6, 2008
    235
    9
    Capacitors store and release charge. For the purpose of rectification, you can look at them like a battery with very limited charge. The capacitor will take or supply current to try to avoid the voltage at it's terminals from changing, but they have limits on the amount of charge they can store and deliver.
