question about butterworth filters
hunterage2000
Joined May 2, 2010
487
Can somebody tell me what the f is in the magnitude formula? I know Ho is the dc gain, fB is the 3db cut off frequency and n is the order.
bertus
Joined Apr 5, 2008
22,278
Can you show the formulas?
The f will most probably be the frequency.
and fB the border frequency of the filter (-3dB point).
Bertus
hunterage2000
Joined May 2, 2010
487
The attached is the formula and the question is:
Analyse the magnitude and phase characteristics of a 2nd order butterworth lowpass filter
not sure how to go about this.
Also forgot to mention that the cutoff frequency is 1000hz
hunterage2000
Joined May 2, 2010
487
looking at the graph on page 5 shows n= 1,4 and 10 and gives different results. so how does this apply to the formula when the magnitude is always 1/root2
bertus
Joined Apr 5, 2008
22,278
The magnitude is only the same for all at the - 3dB point.
Before and afther that point the values are diffetent as you can see in the graph.
Bertus
hunterage2000
Joined May 2, 2010
487
so what is this formula used for? Can you explain what the magnitude and phase is for 2nd order as an example so I can try other orders
