Question about a Crystal oscillator
Discussion in 'General Electronics Chat' started by Hessam555, Aug 21, 2008.
  1. Hessam555
    Aug 13, 2008
    5
    i had a question about a Crystal oscillator. the circuit i have seen says i need a Crystal oscillator that is 4mhz and conected to two 22pf caps. is there anyother way i can make a subtitution for it.
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Do you not like the frequency, or is the component the issue?
  4. blocco a spirale
    Jun 18, 2008
    1,461
    370
    Is this for a microprocessor/ microcontroller/ PIC?
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Crystals are used in certain oscillator circuits because they are far more stable and have a much narrower frequency range than a typical RC or LC circuit. If your circuit had anything to do with timing, you would be very unhappy with it's performance if you substituted an LC or RC circuit.
