Hi all,
This is my first question here and I'm not an EE so please bear with me. I'm trying to temporarily disable the countdown function of a 4060 ripple timer by jumpering pin 11 (clock) to Vss (pin 8). This does, in fact, place the countdown on hold while pin 11 is shorted to Vss, but when the jumper is removed, all countdown times are reduced by 50% on the first cycle i.e. if I'm using the ~15 second output on the chip as the countdown time, it is now 7.5 secs. This only happens on the first cycle after the jumper is removed - all subsequent intervals are back to their normal, expected times. I know I'm describing this poorly, but has anyone seen this behavior from a 4060? Thanks for all advice!
