Question About 3 Phase Balanced Circuit
Discussion in 'Homework Help' started by hitmen, Jan 10, 2010.
  1. hitmen
    Thread Starter Active Member
    Sep 21, 2008
    159
    1) I am given a question in which a delta and Y transformation circuit are placed together in parallel. I know how to calculate the impedance but which set of equations do I use when calculating voltage?
    Also is the voltage phase to phase or line to line?
    Y-transform: V(line2line) = sqrt(3)V(phase) < 30degrees
    Delta: V(line2line) = Vphase
    When they are combined together in parallel, which equation should I use?
    Also, what kind of current am I dealing with phase or line to line?
  2. zgozvrm
    Member
    Oct 24, 2009
    115
    I think you need to post some pictures to clarify the problem...
  3. hadi00
    Jan 25, 2008
    change Y->delta or delta to Y and do the culculations? maybe makes it easier :rolleyes:
