Question #1
Discussion in 'Homework Help' started by mattm, Sep 9, 2009.
  1. mattm
    Aug 5, 2009
    19
    to remove pulsations from a power-supply output what kind of filter should be used?
  2. steveb
    Jul 3, 2008
    2,433
    469
    Easy - a pulsation filter! :p
    Actually, it depends on the details, such as the application and the type of pulsations and the frequency. A low-pass filter or a notch filter could be used.
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    For this, you would usually use a electrolytic capacitor. Although, you will need your diode bridge to rectify the AC. The capacitance value will depend upon the current output needed.
