query on 8051 development board
Discussion in 'Embedded Systems and Microcontrollers' started by abhimanyu143, Aug 29, 2015.
  1. abhimanyu143
    Aug 25, 2014
    211
    Hello
    I need help please look link http://www.ebay.in/itm/201405119441?aff_source=Sok-Goog
    I want to buy that development board. thats why I need some information
    1. does it support keil compiler
    2. does it support flash magic programmer software ?
    3. can it program 89s52?
    4. does it Compatible with Laptops?
    I am not sure but I think keil and flash magic support 89s52
  2. ScottWang
    Aug 23, 2012
    4,930
    777
    1. does it support keil compiler -- I think it is no matter with the compiler, it just the way to send to the uC.
    2. does it support flash magic programmer software ? -- Flash Magic is a PC tool for programming flash based microcontrollers from NXP using a serial or Ethernet protocol while in the target hardware.
    3. can it program 89s52? -- AT89S52/51,P89V51RD2 etc. R&D Project Development board.
    4. does it Compatible with Laptops? -- I don't know what you mean, that is a uC board not the normal computer board.
    abhimanyu143 likes this.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    4.
    That board you linked has db-9 serial connector that is used to connect the board to pc/laptop. In my limited experience modern laptops don't have db-9 serial connector (most manufacturers stopped putting them into laptops some years ago when USB took over). So... you would need USB to DB-9 adapter cable, such cables are pretty common and usually come with Windows driver software.
  4. abhimanyu143
    Aug 25, 2014
    211
    have you seen the Link? I want to buy that board. I am familiar with keil and flash magic. I have been created c code in keil and successfully burn using flash magic I just want to confirm that board will support Keil, flash softwares.
  5. ScottWang
    Aug 23, 2012
    4,930
    777
    All I wrote was according to what you mentioned and linked, the point 2 was the software company declared that they can do, the point 3 was copied from the website you linked.
