Hi - I'm not an EE, just a retired hobbyist, so this might be quite uninformed. I got an 80's-something Tektronix 2445 Scope with two of the four channels working, but some problems with the on-screen text overlays and channels 1 and 2. My "visual inspection" discovered an exploded capacitor on the main power board. So the fact that anything works at all seems a bonus. But before I order and replace some caps, perhaps I need to understand the circuit a bit better.
Part of the power schematic is attached, with the blown 0.068uF cap highlighed. It sits on the mains side of the rectifier diodes And it has another similar mate to the left on the schematic, before the chokes.
1. Can someone explain what the components to the left of the bridge rectifier are trying to do? (The E1001 and E1002 components are gas-filled surge protectors).
2. They have polarity, so that confuses me. And they're across a 230v mains supply. Maybe that is why this one blew up.
3. The oscilloscope has a selectable 115v/230v mains supply. I reckon the 250v rating on the capacitors (according to the replacement parts list in the repair manual) is probably pretty safe in the USA with 115v supplies, but at 230V there is little margin for error. Any comment on this is welcome.
If I replace the two caps with some 0.068uF caps rated at 400v or 600v, does this circuit demand something special: e.g. a polarized capacitor that can withstand more-than-usual reverse voltage? The two original components are quite large solid blocks rather than in metal cans.
Thanks for any advice.
Peter
Peter
