que about Ac analysis
Discussion in 'General Electronics Chat' started by nathalie, Mar 25, 2011.
  1. nathalie
    Jan 9, 2011
    14
    What is the relationship between the voltage output swing, in the class A dc biasing of a Bjt transistor, and the Voltage swing obtained when a an Ac signal is introduced? How does the dc bias voltage effect the ac Voltage gain?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I guess the key might be the relationship between the static bias collector current and the small signal current gain - hfe. I think hfe is fairly stable over a wide range of Ic but it possibly reduces as Ic decreases & nears cut-off.
    The venerable Audioguru is probably the go-to person on this stuff.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Look at the data for the small signal BJT 2N3904 for instance....
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    The current gain of a common-emitter stage is dependent on hfe. This has a strong effect on the input impedance of the stage, but not on the voltage gain as measured from the base to collector.
    The input impedance does influence the insertion gain of an amplifier driven from a significant source impedance, so in this situation the effective gain does strongly depend on hfe. This is particularly important in multi-stage amplifiers.
    One approach to finding voltage gain is given on pages here on the AAC site. http://www.allaboutcircuits.com/vol_3/chpt_4/5.html
    Here you will see the equation Av = β*Rout/Rin. This is valid, but from this you might be tempted to assume that β has a strong influence on voltage gain. Herein lies a fallacy: the point is that Rin is actually a function of β, approximately equal to β*(RE+0.026/Ie) at room temp. This gives us Av ≈ Rout/(RE+0.026/Ie), where RE is the un-bypassed emitter resistance, if any.
    The base to collector voltage gain depends principally on the emitter current, any un-bypassed external emitter resistance RE, and the collector load impedance, including the transistor's own output slope impedance. This article may help with understanding. Note that equations dealing with voltage gain appear on the last page. http://www.seas.gwu.edu/~ece20/fall08/labs/tutorials/Tutorial5_Designing_Common_Emitter_Amplifier.pdf
    It may be also useful to consider the hybrid-pi model. http://en.wikipedia.org/wiki/Hybrid-pi_model
