Hello
I have this antenna name QuantumFX its a rotating antenna for television use ( model ant 105).
Does any body know what type MOTOR is in use in this antenna?
It has two wires come out from the motor, could not be a Servo motor since Servo motor use three wires or a stepper motor use more than three wires.
There a circuit board in the case with the motor.
Can someone explain how this antenna work has control box plus a remote and only one co-axial cable coming from the antenna (in the antenna there circuit board).
How does antenna turn with one co-axial cable and at same time bring signal to the television?
mrel
mrel
