quantum mechanics
Discussion in 'Physics' started by magnet18, Dec 16, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    OK, so what I'm confused about is things like tunneling.
    an electron goes from one side of a barrier to the other. without actually crossing it.
    so what happens? from what I can tell of the universe it that things don't simply disappear.
    go from matter to energy, sure. but disappear and reappear doesn't make sense.
    Do they go into a 4th dimension or something?
  2. BillO
    Distinguished Member
    Nov 24, 2008
    985
    136
    Unfortunately we don't know. QM gives us the probability it will happen, but gives us no idea how it happens.
    In fact, the similarity of the QM Hamiltonian (which has basically no physical interpretation) to the CM Hamiltonian (which almost fully describes the system) has led to some interesting speculations.
    So... Your guess is as valid as anyone's.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I vote for subspace myself.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Kinda like which part of your car is going to break next.
  5. steveb
    Jul 3, 2008
    2,433
    469
    Here is a common sense explanation for something that defies common sense.
    http://www.youtube.com/watch?v=6LKjJT7gh9s
  6. russ_hensel
    Jan 11, 2009
    820
    47
    Actually it does go through it. That is the wave function is non-zero inside the barrier ( expotential decay as I recall ). You need to look at the solutions to the schrodering (sp ) equation to begin to understand it.
  7. amilton542
    Nov 13, 2010
    494
    64
    There is temptation in particle physics associated with the graviton, where dimensions above the third degree could be considered.
  8. magnet18
    Dec 22, 2010
    1,232
    125
    so, it goes through it measurably, but without interacting with it in anyway?
  9. russ_hensel
    Jan 11, 2009
    820
    47
    What do you mean by interact? What is your picture of a potential barrier? We usually compute the function of the particle, not the structure of the barrier.
  10. magnet18
    Dec 22, 2010
    1,232
    125
    By barrier I mean the insulating metal oxide in a MOSFET
    Like, it goes through the barrier and has a waveform and stuff, but dosen't actually leave any kind of mark or scratch on the barrier (obviously not literally, but not metaphorically either)
    New related questions
    does it take time for the electron to cross the barrier?
    Does the electron exist in the barrier at all at any point in time?
  11. BillO
    Nov 24, 2008
    985
    136
    Be careful about assigning any physical meaning to the wave function. The interpretation of it's square is that it gives the probability of a particular event happening. The event could be finding an electron in the barrier. If the wave function falls off sharply in the barrier, then it's square will be very small. The common interpretation of this would be that it is unlikely to find it there.
  12. thatoneguy
    Feb 19, 2009
    6,357
    718
    Remember, most of an atom is nothing. The electron cloud is just that, a cloud of probability of where the electron may be.
    How could a cloud get scratched?
  13. magnet18
    Dec 22, 2010
    1,232
    125
    I know that a cloud can't be scratched :p
    atomic structure is one of my favorite subjects, but I was just meaning it has no interaction with any of the atoms nor their electrons inside the barrier, yet passes through it...
  14. thatoneguy
    Feb 19, 2009
    6,357
    718
    An electron is very tiny and can fit in the "cloud" of electrons forming the lattice of the metal they pass through. It would be something like fitting mercury in between Venus and the Earth without hitting anything, in a very vague approximation, the nucleus would be about Earth's orbit, so Mercury going between say Venus and Earth's Orbit without coming close enough to another electron to be repelled. Chances are low, but it is possible.
  15. magnet18
    Dec 22, 2010
    1,232
    125
    OK, so that makes sense, but if it slides through without touching anything, why does it's energy decrease?
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    I may be misreading your post, but the further out the electron is, the more energy it has. Think about lasers, when an electron falls to a lower level it gives off a photon, when it absorbs a photon it jumps up a level.
  17. russ_hensel
    Jan 11, 2009
    820
    47
    The oxide is not really well modeled as a simple step barrier, to calculate the movement of the atoms ( and electrons.... ) in it you would need much more detail. I expect there is a non 0 probability of displacing these atoms and scratching the oxide.
    Time to cross the barrier: I can think of 2 approaches. The usual model is a plane wave ( not normalized to 1 ) which gives a time independent solution. But you can compute the probability flux inside the barrier. This is more computation than I am up for right now -- my intution does not give me a good hint as to the result. The other way is to make up a wave packet which unlike the first approach is well localized in space. Computations are now probably harder.
    The simple question is does the electron exist inside the barrier. Yes the probability of finding it at any point is just the square of the absolute value of the wave function.
