quantum computing
Discussion in 'Physics' started by saurabh sagar, Sep 1, 2006.
  1. saurabh sagar
    Sep 1, 2006
    Is this possible for quntum computer to see the future.I have read that it can give the answer before u asked the question.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No it is not possible, just as it is not possible to travel backward in time.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Such a computer would be able to finally tell us whether Schrodinger's cat needs burying or feeding!:D
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Surely this would be quite a disturbing possibility should it be feasible. Where exactly have you got the idea of quantum computers being able to see into the future?
    I'm going to disgree there Papabravo, I spend most days at work travelling backwards! :D
    Dave
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    "Let there be light"
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This is similar to Asimov's thiotimoline, that dissolves one minute before water is added to it.
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    How can you question Asimov's Thiotimoline, he demonstrated its workings in his paper titled: "The Endochronic Properties of Resublimated Thiotimoline". Who could question that the carbon in the Thiotimoline molecule has one atom projecting into the future and one into the past! :eek: :D :p
    Dave
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Actually, the model of the logic in a quantum computer being in all possible states at once makes it conceptually hard to decide if any one transistor is open, shorted, or working. I'd hate to write a compiler for one:
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    SELECT CASE (ANY)
    CASE EVERYINSTANCE
    DO ALL
    NEVER END SELECT
    Could be a bit strange for all states to be true and false all the time. Hard to tell what was going on unless the computer actually caught fire.
  10. n9352527
    Oct 14, 2005
    1,198
    This is actually why some people say that quantum computer can predict the future. In this case not really the future, but the result of a calculation even before the calculation's result is obtained. If all the possible states can exist at once, then it follows that all the possible results are exist.
    It's a far reaching field, which needs considerable might to understand and even more to apply in any useful scenario.
  11. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    But then that would mean it is predicting all possible future permutations, and for it to be a true prediction of the future we would still need to interpret the result (i.e. the whole idea of converting data into information) - since that would mean we need to see into the future then the validity of the data from the quantum computer is irrelevant.
    From the little musings I have had with quantum computers, from what I can see the key advantage is that since multiple states can co-exist we can perform multiple-level calculations therefore increasing the computational capabilities over conventional computers.
    Dave
  12. sci-3d
    Aug 22, 2006
    51
    Making logic gate from binary state of electron spin up an spin down may be far away from our time. However, some day in the future, this will be real.
  13. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Based on the progress in this field, there is no doubt that at some level this will happen. However, the question posed by the OP regarding seeing into the future is somewhat in the realms of science-fiction.
    Dave
  14. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Not a problem. We can use politicians to interpret the data. They are almost always predicting the furture. After the fact they almost always predict they were right.
    Sort of a "fuzzy quantum." :)
  15. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    :D Like it!!
    We finally have a use for our politicians. Ol' Tony Blair might be advised to look into this as a potential career move since he has very little time left as one of them.
    Dave
  16. xphere
    Member
    Sep 29, 2006
    15
    We see into the future all the time, the problem is bringing back the information before the present. The fact is that we usually see the future just in time for it to become present.
    So the problem is perspective and how to change perspective instantaneously from all perspectives to any perspective. Which im pretty sure quantum theory says can't happen.
    (i think i need more coffee)
  17. Wijssegger
    Nov 23, 2006
    Hi all:)
    The whole area of quantum computing is fascinating. The photon is probably going to be the electron of the future. Photonics will be my specialty, so I want to learn all I can. Thank you all for your sense of humor, as a lot of this stuff is heavy going.:eek:
  18. nomurphy
    Aug 8, 2005
    567
    12
    Yes. The quantum computer will provide you with the prescient answer of "42" -- but then you will have to build a much more powerful computer to figure out the question.
  19. Papabravo
    Feb 24, 2006
    10,340
    1,850
  20. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I always thought the question was: "What is the meaning of life?"
    It would help if I'd actually read the book!
    Dave
