Quadrature encoding screened lead
Discussion in 'Embedded Systems and Microcontrollers' started by camerart, May 3, 2016.
  1. camerart
    Thread Starter Active Member
    Feb 25, 2013
    518
    30
    I'm using quadrature encoding on a project I'm working on. I think it is better to use screened lead for the signals, and have been testing using good quality stereo cable, which is quite stiff. I would prefer more flexible lead if possible as it needs to coil a little. Does anyone have any suggestions for what would be the most flexible type of lead for my purpose, please? It also needs a small 5v power wire, plus gnd. (Can the screened earth be also used for power?) All less than 1Mtr.
    Camerart.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Check out headphone wire.
    John
  3. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,526
    No you should not use the Shield/Screen for power.
    Particularly if using single ended output and not using differential output, is it a noisy environment?
    Max.
  4. camerart
    Feb 25, 2013
    518
    30
    Ok, John
    Hi M.
    What is single ended and differential output?
    I have the ground connected only at the circuit end.
    Noisy? The motors are switching and commutating, and there are transmitter/receivers all withing 1/2 Mtr.
    Is Joh's suggestion of headphone wire ok?
    C.
  5. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,526
    Encoders often do not act alone but in an otherwise electrically noisy environment as in CNC machine etc, so it is important to prevent noise appearing in the signal in this case a differential output such as RS485 driver is used, for short distances you can get away with single ended. But should still important for shielding. See maxim MAX9112
    Could be overkill maybe in your case, but I use individual shielded pairs with OA braid shield.
    Max.
  6. camerart
    Feb 25, 2013
    518
    30
    Ok, thanks.
    C.
  7. BR-549
    Sep 22, 2013
    2,184
    421
    Pardon my ignorance guys. Googled the term with no luck.
    What is a screened lead?
  8. camerart
    Feb 25, 2013
    518
    30
    Hi B,
    The insulated +v wires in screened lead are covered by braiding, which is the Gnd side, instead of two parallel wires. Used in earphone, microphone, USB, signal cables to stop interference getting into the signal.
    C.
  9. BR-549
    Sep 22, 2013
    2,184
    421
    Still have no idea. You said it was stiff. Could you possibly mean coax cable?
    What term do you use, when you search for this product on google?
    All I get is screening for lead poisoning.
  10. recklessrog
    Member
    May 23, 2013
    349
    102
  11. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,526
    The encoder cable I use is actually intended for Data transmission and it has each pair shielded by foil shield and has an overall braid shield.
    It also has one pair one gauge up from the rest for the power.
    But this is used in a noisy industrial environment.
    NOT cheap though.:(
    Max.
  12. camerart
    Feb 25, 2013
    518
    30
    I looked in my old cable box and found some quality Phono cable with four individually screened cables, and it is remarkably flexible too. I'll use that.
    Thanks to everyone.
    C,
