Quadratic Formula
Discussion in 'Math' started by Thinker, Feb 1, 2007.
  1. Thinker
    Thread Starter Active Member
    Jan 9, 2007
    61
    Okay.
    I have to solve a algebraic expression using a quadratic formula.
    This is it:
    X2 - 2X - 6 = 0
    I used the quadratic formula on your site here to help me. So...
    a=1, b=-2, c=-6
    X= +3 ± |4 - 4 * 1 - (-6)
    2 * 1
    = 3 ± |0
    = 3 ± 0
    .........and I got 1.5
    But when i put it to the equation X2 - 2X - 6 = 0 I get 0.75, it should be 0 right?
    Does anybody know where i possible went wrong?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If b = -2 then minus b must be ceteris paribas 2. N'est pas?
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Hi Thinker,
    You appear to be a little off course with this one. Papabravo is correct: --2 = +2. Additionally, what you have in the square root is wrong:
    If b = -2, then b^2 = +4
    And if a = 1 and c = -6, then 4ac = 4*1*-6 = -24
    So your expression in the square root is (4 - -24) = +28
    If you follow the quadratic equation exactly you should get the answer to be x = +3.64575 or -1.64575
    Have another go and post up if you have any problems.
    Dave
  4. Thinker
    Jan 9, 2007
    61
    Thanks Papabravo and Dave
    I'll test it out and get back to you, I'm a bit busy now.
  5. Thinker
    Jan 9, 2007
    61
    Okay i worked everything out again and this is what i got:
    (3.64575)2 - (2 * 3.64575) - 6 = 0
    13.29150 - 7.2915 - 6 = 0
    That is for the 3.64575 answer. I don't know what i was thinking when i put -3 in the equation instead of -2! :confused:
    Thanks Dave and for the help. :)
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Don't forget that x = -1.64575 is also a solution to the equation. This arises due to the fact that there is a +/- in the quadratic formula and provided 4ac =/ 0 then there will be two solutions.
    Dave
  7. Thinker
    Jan 9, 2007
    61
    Okay Dave, thanks.
    (sorry i know this reply is a bit late)
