QFN/MLF socket
Discussion in 'The Projects Forum' started by Konstabel, Feb 11, 2008.
  1. Konstabel
    Thread Starter Active Member
    Jan 31, 2008
    52
    What is the best way to incorporate this kind of chip onto my pcb design? I would like to use a socket for incase it gets busted. Where can I find footprints for this type of sockets (64pin)
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
  3. scubasteve_911
    Dec 27, 2007
    1,202
    You're better off getting a cheap PCB made from www.4pcb.com (33 each deal)
    Better grab some solder paste and a toaster oven/hot plate too :p
    Steve
  4. John Luciani
    Apr 3, 2007
    477
    If the QFN is part of a large design board or if it is likely to need replacement
    make an adapter PCB otherwise solder it onto your main PCB.
    Make sure to use the recommended footprint. If the part has a thermal pad the usuall
    recomendation is mutliple small PCB pads with vias. Solder wicking in the vias
    really pulls the chip tight to the board.
    The boards I did were soldered on a $20 hot plate which worked well.
    (* jcl *)
