Q: Square Wave through series RL
Discussion in 'Homework Help' started by andrewintejas, Dec 7, 2014.
  1. andrewintejas
    Sep 20, 2014
    8
    I have a question about the attached RL circuit, which produces the corresponding voltage graph under the influence of a square wave.
    As you can see in the voltage graph, there's a discontinuous voltage jump to negative for the Inductor when the step voltage turns off. Is there an implicit current direction change in the circuit occurring with the square wave 0 state? An intuitive reason for the polarity change in the inductor is otherwise escaping me.
  2. ScottWang
    Aug 23, 2012
    4,934
    777
    You can see this animator for coil, you will also know why the relay need a diode for back emf.
    absf likes this.
  3. andrewintejas
    Sep 20, 2014
    8
    Thanks guys!
You May Also Like:
Load More
