Q Point
Discussion in 'General Electronics Chat' started by nagarjun, Jan 2, 2008.
  1. nagarjun
    Jan 2, 2008
    What exactly do you mean by a Q point?????
  2. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Q is short for quiescent, as I am assuming your refering to transistor or tube biasing. If your not, then expand on your inquiry.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  4. Snigdha Bose
    Nov 2, 2008
    we set fixed levels of certain currents and voltage in a transistor. now these values of current and voltage define the point at which the transistor operates. this point is known as Q point or operating point or Quiescent point...
  5. paddy353
    Aug 15, 2008
    Q-point is the point in design of transistor circuits where, under certin conditions, the AC and DC load lines intersect. By designing your circuit to have the DC load line half way on the AC loadline, it allows for a full AC voltage swing on the input. If the Q point is not in the middle of the loadline, clipping will occur.
