Q-Point Voltage
Discussion in 'Homework Help' started by Stereoblind, Apr 29, 2015.
  1. Stereoblind
    Mar 10, 2015
    14
    I'm currently working on tutorial problems for setting the q-point for bjt circuits. When talking about Vq I'm getting a bit confused though. If Iq is the quiescent current I can see where you would measure that. But across where would I be able to measure Vq? Is it across the output of the transistor? Or is it just an imaginary point that I can't actually investigate with a voltmeter on the circuit?
  2. ericgibbs
    Jan 29, 2010
    2,595
    393
    The q-point is a point on the transistor collector/load line, measured at the collector.
    Watch this
  3. MrChips
    Oct 2, 2009
    12,636
    3,454
    The voltage on the x-axis is the voltage across the collector-emitter, VCE, i.e. the voltage at the collector with respect to the emitter .
