q-point of a transistor ..help
Discussion in 'Homework Help' started by herbgriffin, Feb 17, 2011.
  1. herbgriffin
    Feb 14, 2011
    11
    we are tasked to make a bjt amplifier, and i don't know what values of Ic,Vce ..Rb and Rc and other values....because i don't know how to find the operating point of the transistor....
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    65
    Please give all the parameters you need to work under,
    such as load impedance, or signal voltage, power supply, ect....
  4. herbgriffin
    Feb 14, 2011
    11
    we are given an input of 50mVpeak and expected output of 10Vpeak to peak
    and beta is 69.28 ....
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    You cannot buy a transistor that has a specific beta of 69.28. So we design circuits for a transistor that has a typical beta of 69 but could have beta from 35 to 140. Then any transistor with that part number will work.
    You need a voltage gain of 200 so the load resistance must be very high or use more than one transistor.
  6. Adjuster
    Dec 26, 2010
    2,147
    300
    It may be easier to obtain the required voltage gain and output swing if you use a rather bigger supply voltage than you might at first think necessary. The voltage would of course need to be suitable for the transistor used.
    An adequate supply voltage will allow you to use a big enough collector load to obtain the required gain. If possible, it might be better to use an even larger load resistance so that somewhat more voltage gain is available, and then to set the gain to the required level by inserting a small additional (undecoupled) emitter resistance.
