Q in loop current method ....
Discussion in 'Homework Help' started by Hannibal666, Apr 22, 2016.
  1. Hannibal666
    Jan 25, 2016
    12
    how to solve this in loop current method??
    how can I solve i1 and i2 and i3
    if there is a current source "(2A)" in the middle ! :((
    please help me with details , cause I`m a beginner
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Well, since you don't bother to even define what i2 and i3 are, how do you expect anyone to be able to help you find them?
    Since this is Homework Help and not Homework Done For You, you need to show YOUR best attempt to work YOUR homework. It doesn't have to be complete or correct, but if you don't show use your efforts, it makes if very hard for us to tell where you are having problems and to help you overcome them.
  3. Hannibal666
    Jan 25, 2016
    12
    I found the answer
    it can be solved by supermesh method.....
    thanks alot Mr.WBahn
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Why do I have the feeling that "found the answer" means just what it says -- that you found a solution worked by someone else? Oh well.
    Using a supermesh is certainly one way, but not the only way. A trivial rearrangement of the parallel branches yields a circuit that has three meshes, one of which is trivial and the other two of which are just ordinary meshes.
