[Q] How to calculate CRC
Discussion in 'Programmer's Corner' started by Mohannad, Mar 15, 2011.
  1. Mohannad
    Mar 15, 2011
    Hello every one :)
    I would to write simple code in PIC 16F877A (in MPLAB), to communicate with a HMI
    that uses Modbus protocol .
    Is there any one have wrote these code , because I want the CRC calculating block
    thanks alot...
    Best Regards,
    Mohannad.​
  2. t06afre
    May 11, 2009
    5,939
    1,222
    MPLAB is just an IDE. Which program language/compiler do you use?
    Mohannad likes this.
  3. Mohannad
    Mar 15, 2011
    Iam using assembly, this is simple code
    START
    MOVLW H'00B4'
    MOVWF H'A0'
    GOTO START
  4. t06afre
    May 11, 2009
    5,939
    1,222
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    The trouble with CRC algorithms is finding test cases that you know the answer to. If you code it and it doesn't work -- what do you do then?
