Q factor, resonant frequency and me banging my head against a wall...really hurts
Discussion in 'Homework Help' started by ninjaman, Dec 14, 2014.
  1. ninjaman
    May 18, 2013
    306
    hello
    I have a series RLC circuit. I have a resistor of 4620 ohms (measured), capacitor of 1uF and an inductor of 151mH.
    I have found the reactances at 1kHz. 951 ohms for Xl, 161 ohms for Xc. approx. values.
    I have Q of 0.0841 from 1/r ((sqrt) L/C) = 1 / 4620 * (sqrt) 0.151 / 0.000001
    I have a bandwidth of 4955Hz from below. subtract first frequency from second.
    BW = Fr / Q
    I have tried this a few ways by transposing for different values and I cant get any of them to stick. I get odd values all the time
    I tried calculating Z using square root of R^+(Xl-Xc)^2, I got 4687 ohms for this. so Z / R = 4687 / 4620 = 1.014
    getting very funny values here....though im not laughing!!!
    any push in the right direction would be great
    fantastic resource this!!! I really like it!!!
    simon
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    It's not clear what your problem is. What do you mean "can't get any of them to stick" and "funny values"?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I was wondering that myself, but you beat me to it.
  4. ninjaman
    May 18, 2013
    306
    I tried the Q formula, 1/r * (sqrt)L/C and got 0.084
    I tried Q = Z /R, calculated Z from (sqrt) R^2 + (xl-xc)^2, for Z I got 4687 ohms. this over R, 4687 / 4620 = 1.01
    so I have two values for Q, 0.084 and 1.01
    then I have
    BW = Fr / Q
    BW from the multisim analysis was 4955Hz, Fr is 409 Hz, I tried rearranging this to find Q and got a different answer. I tried this with both values of Q from above and didn't get the 4955Hz bandwidth.
    so everything is different.
    that's what I meant by funny values
    the closest I get is Fr/Q using 409Hz / o.084 = 4869Hz. but that isn't 4955.
  5. shteii01
    Feb 19, 2010
    3,500
    511
    Your ability to present information in clear and organized manner sucks!
    Put all the values in a table. Calculate percentage errors for values that you were tasked to find. If percentage errors are less than 5%, then you fine.
  6. ninjaman
    May 18, 2013
    306
    where does the percentage error of 5% come from. is this to do with the accuracy of measuring equipment?
    shteii thanks for the help but I feel that comment was a little rude.
  7. shteii01
    Feb 19, 2010
    3,500
    511
    That is what my instructors asked of me. If the percentage error was more than 5%, then there was a problem. Even with the percentage errors of 5 or less we had to had an explanation in our lab reports for why we had an error.
  8. MrAl
    Distinguished Member
    Jun 17, 2014
    2,554
    515
    So you need to calculate the Q to within 5 percent then?
    What are you trying to calculate?
    If you take F/BW you get around 0.1 so that's low.
  9. shteii01
    Feb 19, 2010
    3,500
    511
    5% or less is what I said, not OP.
  10. JoeJester
    Apr 26, 2005
    3,401
    1,218
    Here's a reminder about resonant circuits
  11. MrAl
    Jun 17, 2014
    2,554
    515
    So what exactly is he trying to calculate then, and to what accuracy?
  12. JoeJester
    Apr 26, 2005
    3,401
    1,218
    The op has not asked a question yet. He just wanted a push in a direction....
